Hi ,,, We have a 206cc for the last two years have had no problems until now.The drivers and passenger windows have stopped working when the switches are operated, and the roof will not operate.
when the roof catches are released and the roof switch is operated there is nothing , the pump does not operate. Have tried all the fuses I can find and all are okay , are the problems linked .
windows and roof
Slo
Re: windows and roof
Its probably the microswitch in one of the roof latches, do you get the bong when you open them? If the car doesn't detect the latches are closed when the roof is up it disables the windows.
chri51808
Hiya,
I have the exact same problem... The mirrors move perfectly and there is absolutely nothing coming from the roof switch no beeping or noises of any kind.
Where would the micro switch be found on the car and how much are they to buy.
Thank you soooo much
There is a whole section on the roof and potential problems/fixes .. try a search or three!
