2006 Peu 206cc 1.6. The fans not coming on when hot but I can't find the 2 relays most on here write about.
The wiring from the fan goes out under the passenger side headlight. I cannot see any covering to the left, drivers side of the fan. Is there an area under the wheel arch cover, passengers side that these relays can be???
I'm at my wits end, helps seriously needed.
Relay location
leegsi
Re: Relay location
They are behind a panel behind the grill.
Remove the grill and look for a panel this shape (The relays are on the back so you wont see them).
This is one of the 3 pins that need to be removed:
