Hi all
206cc 1.6 2004
I have anti pollution fault, fault codes are PO121 and PO123. I believe this is the TPS but am having trouble trying to locate where to buy one, I am in South Wales.
thanks
Help with fault codes
Re: Help with fault codes
Ebay?
happybunny
Would it specific to the cc model? only brings up 206 hatch when I enter 206 cc
Anything with the TU5JP4 engine- Peugeot 206/306/307/partner and Citroen c3/4 Berlingo/Xsara.
The numbers on the TB must be the same as there were a couple of different types used and different plugs. Start off with something the same year. Then check the numbers
