Connections under seat
garyclarke1962
Post by garyclarke1962 »
I took the seats out of my 51 reg 206cc because the airbag light is on and i wanted to see if i could find any unconnected wiring. I found 3 unconnected connectors, a red, a white and a green connector.
Could someone confirm these are connectors for the seats? and which one(s) do i need to attach resistors to, to get rid if the airbag light?
Re: Connections under seat
Firstly have you diagnosed the promblem with a code reader? Have you tried reconnecting the plugs?
I won't help with bodgery as this is a safety feature, so if you want to mess around with resistors you're on your own. If you get it wrong, you may render the whole airbag system U/S.
If you want help with a proper fix, then fault codes would be needed.
See this thread-http://www.peugeot206cc.co.uk/viewtopic.php?f=1&t=15470 and take notice of my comments.
