Can ayone identify this plug? Car is a 2002 02 reg 2.0 manual with auto aircon and ABS
Swapped my broken battery tray today and discovered not only acid all over the gearbox and an empty battery cell (but battery still working?) but this plug skulking away down the side of the battery box and nothing likely for it to plug into.
Is it a spare?
Is this a spare plug or is something missing?
Slo
Slo
Re: Is this a spare plug or is something missing?
18 views and no one knows? Ok i've been told its probably the fuel cut off switch thats not needed on a multiplexed car (bsi controlled) can anyone confirm this?
Its not the alarm connector either as thats plugged in.
Don't recognise it, but with a plexed car you would have a fault stored from whatever it is plugged into- so I would say spare plug, poss speedo drive if yours is the later wheel sensed system
Slo
If its a spare then wouldnt every car have it? Surely someone must recognise it or have something plugged into it? Whats plugged into your Col?
Not sure. Can look on Sat if you like, Sorry I'm away 'til then.
Slo
No worries Col whenever no rush just curious as im new to these cars and I like to know what you can add on.
Slo
The wires on this plug are
1342 Yellow
1352 White
1362 Red
Blue but theres no wire number that I can see
Cant find it in the haynes manual wiring diagrams either
1342 Yellow
1352 White
1362 Red
