My wife has had the car for a number of years with a few of the usual problems worst being the real axel
But the roof has never has an issue, until now.
so a discription of the issue:
Roof operates kind of normally goes up and down fine. but it is as if the final action on close is not completing.
She came home saying the car is bleeping at her while she drives it, so i took out for a run and rightly so once over the 5mph mark the bleeping starts, get both the short bleeps and the fast bleeps.
Rear heated window not operating either
I opened the front latches and got no bong, press roff button and it starts to operate but did not lower the windows, I closed the front latch and open the windows from the window switch, the released catch and tried to open roof. hey presto pump operates and boot opens up roof folds down, parcel shelf pops out and boot closes and hear both catches lock, but the motor continues to operate and get no final bleep. eventually after around 10-15 seconds the motor stops and the continuious bleeps start.
so press button to raise roof and again all works as should, boot opens parcel shelf folds down and roof lifts up into place, then boot closes again hear both catches lock and again no bleep, mottor continues untill fail and continious bleeps.
So i try the BSI reset as stated in capncol post in topic.php?f=23&t=13473. (i'm not allowed to post links yet
issue still the same.
So now i go about checking all the 12 mirco switches, i say 12 rather than 11 at the tailgate lock has 2 mirco switches locted in it, with a multimeter all working correctly, also checked each operating with the roof action as manually opertated the roof to see if this would fix this issue.
Checked the fluid level in the pump and is fine.
pressed down on the locks after close to double check they locking in.
I am now out of ideas, all I can think now is the roof ecu is corrupted and will need replacing, but I thought maybe I should ask here to see if anyone else could shed some light on it.
I have not had it read on a reader as of yet as I do not have one capible of reading roof problems.
Also to add the battery had not been disconected or gone flat nor was the roof opened or closed recently and not completed a cycle. No chance the roof coming down in the weather we having
anyways thank you for reading and hopefully I can get this fixed so my wife is happy again
