New Window Switch Ghost Electrical Problems
tyealia
Post by tyealia »
New Switch for Windows- So I have been battling trying to get a new switch for my side windows. I think condensation or a spilled drink :P may have broken the switches ability to lower the driver side window, i can do all functionality with all windows but lower it. So I ordered a piece from a scrappy
My version is 2005 206cc
scrappy was 2008 206cc, the switch almost worked EXCEPT some weirdness.
Also had bought a new switch of unknown year
Weirdness
1. Only lowers or raises the window COMPLETELY, no half way or a bit, once you push the switch your all in.
2. all windows lower when you turn on the car and release the brake, or clutch
3. all windows lower when you turn the car off, as soon as key is turned to off all windows lower
This has driven me mad, is it a ghost switch? I also ordered another one from a different 2008 and same problem. I can only find a 2003 scrappy im going to maybe order that one and hope it works. Looks like after 2005 they changed the switch type ever so slightly? Beats me Hopefully someone can shed some light on this.
Here is a video of the problem I took
https://www.youtube.com/watch?v=g1J1L3R14fY
[youtube]v=g1J1L3R14fY[/youtube]
[youtube]g1J1L3R14fY[/youtube]
Peugeot 206cc 2005 (2014 newish motor)
1.6L, 4 cylinder , 50 litre
tyealia
Re: New Window Switch Ghost Electrical Problems
Post by tyealia »
Bump
I tried buying another switch from a regular 206 this time and still same problem. Anyone know anything about this?
tyealia
Post by tyealia »
I am guessing that any switch after 2005, 2006 or 2007 is new with some small detail that causes this problem because the one I put in is a 2008 and it has this same issue. Maybe someone on the forum knows more, im debating getting one from a 2003 scrappy I have found as a next step
bertie1
Post by bertie1 »
spooky ! havent a clue but reckon time for a auto electrian to have a look
my fleet::: 2x peugeot 206cc 2.0 si6 mercedes sl aston martin db9 volante 1937 ford model y hotrod range rover
I'm not convinced the fault is with the switch. It could be BSI or Roof ECU. I agree with Bertie1- Auto electrician time.
What happens with the switch disconnected?
tyealia
Post by tyealia »
Went to an electrician and he told me that the switch simply wasent the same it looked almost exactly the same had the same amount of pins on it but was different.
So looks like im screwed I have been through 3 switches now, all after 2005, my last hope is a switch pre 2005 for the cc
