DIY Coolant change question
mariusing
Post by mariusing »
Hi all bros,
according to the manual on this forum /repair-206/206/info/gb/b1gi02k3.htm, I cant find the radiator drain plug and the engine drain plug, would anyone could help post a photo showing the exact location of those two plugs? Thanks so much for the great help.
/repair-206/206/images/b/b1gk06kc.gif
/repair-206/206/images/b/b1gk07zd.gif
:love-thx: :love-thx:
Re: DIY Coolant change question
If you can't find the drain plugs then the easiest way is to disconnect the bottom hose from the radiator.
mariusing
Post by mariusing »
Capncol wrote:If you can't find the drain plugs then the easiest way is to disconnect the bottom hose from the radiator.
Will this also clear the coolant in the engine?
99% if you leave header tank cap off. You're going to flush it anyway surely. Don't forget to bleed system afterwards.
