engine light on
performancevw
engine light on
Post by performancevw »
I have a peugeot 206 1.1 46000 miles and looking for some advice on it
the car is superb in every aspect but only 1 issue:
the yellow engine check light comes on the dashboard if i press the accelator pedal hard ( like revving up and down quickly), Some times happen when you start the car in the morning but if you turn the ignition off and turn it on again and wait for few seconds then no light
had new ignition coil spark plugs radiator crank sensor etc had few fault codes (injectors related) but garage ruled out every code as every thing came up fine after test
car starts first time, no idle issues, nice quiet and calm runner. but just upon pressing the pedal the yellow light comes on. car drives fine with the light on. also happens when gear change is applied and quick gas to get moving but if pedal is pressed gently and lightly then light wont come on.
Any ideas what can it be, appreciate the advice, thank you
