206 CC, 02 plate
Heater display is digital and display is fine. When switching on heater fan nothing happens then randomly it works. When it works all speeds work then will stop then start again randomly. The fan motor clearly works I suspect the reostat maybe faulty. The other thing was the display didn't light up tonight when lights were on then came on and were fine.
Can anyone clarify the heater motor behaviour ?
Horns dont work despite changing a blown fuse no 13
HEATER FAN INTERMITANT
- keithholman
Re: HEATER FAN INTERMITANT
interesting because my wife's 206 does the same would be very interested in the reply's
The plug on the heater motor has a tendancy to melt and make the connection go a bit intermittant
Enright
If you need any replacement heater components, let me know because I have a full set for both types.
BCingU,
Neil.
Neil.
