turning problem
jaybluecc
turning problem
Post by jaybluecc »
Hi I was wondering if anyone could give me an idea or so, recently when I turn left on bendy roads the car wants to lose control and the backend wants to go, its as if one of the front wheels are turning more than the other, yet I dont have the problem turning right. So im slightly confused, however I know that the rear tyres are a slight different size, could that be the problem? Any clues to this would be extremely helpful.
Re: turning problem
That recently happened to our hatchback and the lower balljoint was worn ..
Could also be the tracking needs checking/adjusting.
Also, what do you mean by different size? Both must be the same size on the same axle by law, but I assume you have different tyres on front and rear? That might not help.
jaybluecc
Re: turning problem
Post by jaybluecc »
Hi, yes I ment different tyres on rear to front, will try check these that u mentioned, thanks for the help.
