Does radio need code if I disconnect the battery?
SAnt
Post by SAnt »
I need to replace the cigarette lighter, so need to disconnect the battery at the terminal. Will the radio need a code to work after I reconnect the battery? The previous owner annoyingly lost the code card for it :(
Thanks in advance!
2002 206cc 2.0 Manual
Re: Does radio need code if I disconnect the battery?
Yes it will be OK. Just follow the proper battery disconnection method.
SAnt
Post by SAnt »
Glad I asked now as I did not know there was a procedure! Thanks for the very big heads up on this :)
Enright
Post by Enright »
If the radio ever forgets its code due to electrical glitches, then it's the VIN number, but you need someone with Peugeot Planet and a diagnostic lead/interface to programme it back in for you. It only takes a few minutes but garages will charge an arm and a leg for this "specialist information"!
BCingU,
Neil. ;)
never had to on our 2002 mux car, but had to re-enter code on pre-mux 2001 CC
emmababes66
Post by emmababes66 »
my radio/cd player is broken im changing it for the same 1 thats already in the car (same model number) will this need coding into my car as i don't have a code for the 1 that's present
is it easy enough to do it yourself or does it need to be done by a auto electricain
Enright
Post by Enright »
Same answer as my post above - the VIN stored in the new CD/radio will be from the vehicle that it came out of. So it will need programming by someone using PP2000.
BCingU,
Neil. ;)
