Central window switch replacement
ianl205cc
Post by ianl205cc »
The combined window/mirror central switch unit in my car is faulty. It is a double manual switch with the number on the back [11857]. I had a quick look on eBay this evening and found one that looks identical but with a different part number [11530] and another with the correct part code [11857] but this one has the driver side auto button. :?
What should I look for - correct code or correct looking part? I wouldn't mind the auto option if it is OK to do so and doesn't blow fuses or do anything bad. :dance:
CjMatthew
Re: Central window switch replacement
Post by CjMatthew »
11530 has 6 pins and 11857 has 7 pins as long as i know. Dont know if u can use any. Check your connector if it is 6 or 7 pin.
