Garage near Chelmsford and head up display problem.
sandonsimmo
I have just bought a 2005 model 206cc 2 litre and wondered if anyone could recommend a good local independent garage in or around Central Essex - I live in Chelmsford. The car will need servicing etc and frankly I think the franchise dealer is likely to be a bit pricey. Thank you so much. As an aside, the car seems to have a bulb failure in the head up display where the radio stations etc are displayed. Does anyone know if this can be remedied by a simple build change (at the garage) or is this a replacement unit? Again thank you in anticipation. Kind regards from a new member.
Re: Garage near Chelmsford and head up display problem.
Welcome to the forum.
Bulb failure is common in that binnacle and you can search the electrical forum for a "how to" if you want to have a go yourself.
BTW I have deleted your duplicate post.
sandonsimmo
Thank you Col. Much appreciated.
