206 cc tyre size ?
glenn
206 cc tyre size ?
Post by glenn »
Hi we have just bought a 206 cc 1.6 16v it has steel wheels and trims fitted the tyres are all 195/55/R15 is this right as the steering seems heavy :hmm:
Re: 206 cc tyre size ?
Sounds right ... type your reg into an online tyre dealer like blackcircles or mytyres and it will tell you.
If steering is heavy check they are correctly inflated and then you power steering fluid is topped up. Also make sure the auxiliary belt is not slipping as this powers the steering pump (aux belt is the one you can see at the left of the engine).
After than it's checking the suspension and steering rack, etc.
glenn
Post by glenn »
thanks Gazza the tyres where the right size but very worn new ones sorted the problem out along with tracking adjusted .
