roof!!
mikanalia
roof!!
Post by mikanalia »
I have recently bought a 2001 2ltr 206cc, I usually drive Golfs but have to say I love this car, it makes me smile every time I see it! BUT............ today I thought id take the roof off, and it wont work!!
I've only had it down once, on 31 December, the day I got it and not since, so am miffed that it wont work!
I unclip the lid, do the thing in the boot ( am good at technical!) but the windows wont go down ( They do when I fasten the clips again ) and there's a beeping on the dash, and no flashing lights.............. I've found the 2 white loops, turned them 90 degrees and pushed them back in, and no difference, I've read the posts but cant find the switch in the boot............... do you think its doomed?? I will be so disappointed if it is!! HELP??? :? :? :?
Mike Clapham
Re: roof!!
Post by Mike Clapham »
Hi, Could be a faulty micro switch or the on-board computer could be iffy, I got mine stuck after repairing the leaky seals, I found that the computer went funny because I had to stop the roof half way, there is two micro switch's behind the rear seats and the one closest to the seats when pressed allowed me to complete the roof cycle and now works correctly. There is a way to operate the roof manually, you open the boot, using the alan key in the bottle holder this fits into the white circle with the hole in it (Hydraulic dampener relief valve) Turn anticlockwise, pull the cord on the left to operate the cover actuator release, un-clip the two white clips in the boot to release the lid from the boot then close the boot, un-clip the roof, two person job to lift the lid then fold the roof into the boot, close the lid but do not close fully, open the boot then close the clips, turn the alan key clockwise to engage the hydraulics, close the boot :) enjoy the sun, do in reverse order for closing, you could try automatic mode in-case the on-board computer hadn't completed it's cycle. You can also operate the roof if the windows are stuck - pull on the roof switch then while pulling turn on the ignition, there will be a series of beeps then let go of the switch then operate the switch - the roof will fold regardless of the window position.
2003 206 CC 1.6 silver :) 1.3 Fiesta style Silver :) Renault Megan copay 1.6 Sports edition Orange.
Can't wait for a nice sunny day....Just because....I have Air conditioning without the AC turned on and my friends can't ;)
Enright
Re: roof!!
Post by Enright »
Mikanalia - where are you? Can you put your location in your profile? Someone may be near enough to be able to help.
Right - to fault finding: With the blind in the correct postion in the boot, and engine running, when you undo the 2 roof clips do you hear a bong?
BCingU,
Neil. ;)
