hi first tie here got my daughters 53 plate 206 flushed out system - rad-flush. re cleaned till clean water showed. filled with coolant and some radweld.also put in new thermostat. no leaks and temp slowly creeps up to near 90 in about 15-20 mins. temp fine about 85-90 when driving and all hoses nice and hot, but no hot air in car all dials and switches fine all work. air is just of cold at fan speed 1 any higher there is no heat at all. used bleed nipple on hose for heater hot water came out of there so this has ne puzzled am i looking for something else but dont know what. can anyone help.
David graham
no hot air
Re: no hot air
I'm guessing you flushed the system due to a problem (sludge??)
It could be that your flushing attempt didn't get as far as the heater matrix, and that is still blocked, or you moved some of the sludge from the rest of the system into the heater matrix. So I would take off the heater hoses and flush just the heater matrix and try again (without the radweld)
davidtechy
Re: no hot air
many thanks will try in the morning and let you know how i got on.
