HII all
so, I get my first 206 cc.
I have a problem with the roof- it is not go open.
I open the 2 letch's but their is not a sound or beep.
I opened it yesterday and it was worked perfectly.
I heard about a reset to the roof computer,
do you thins it can help?
please help
roof problem please help!!!
Re: roof problem please help!!!
Hi Osher, I have moved this into the Roof section for you so that it is the right section and will be easier to track for other people.
It would seem one of the micro switches in the top of the windscreen pillars was sticking and has now freed off because you say the roof worked properly yesterday.
There is no point in trying to reset anything if it is now working. You may make things worse.
If it happens again, check the microswitches here
