Radio working but no reception
WebbyAintree
Just turned on the radio and all i am getting is static on AM and FM. CDs work fine. Its as if the radion is disconnected from the antenna.
Re: Radio working but no reception
aerial lead may have fallen out at back of radio.
If you plan to pull tbe radio make sure that you have the code if it's an earlier model (small dispkay in headunit).
Also aerial connection at antenna is a known weak point due to water ingress.
