05 206cc window
lisalou
05 206cc window
Post by lisalou »
my drivers side window doesnt go under the seal when i close the door the door closes fine though,and it goes under the seal if i open the window and close it again. i can push it under the seal once the door is closed. ive just bought this car so i dont really want to spend a huge fortune x
rfman
Re: 05 206cc window
Post by rfman »
Try putting a little silicon grease along the seal, that should help.
Re: 05 206cc window
If rfman's suggestion doesn't do the trick, the door glass guide frame may need adjustment. I can tell you how if needed.
rfman
Re: 05 206cc window
Post by rfman »
can you give me the instructions to adjust the window guide please? I was going to try adjusting the door on mine to see if it would fix the passenger window on mine.
It's OK, I found your answer /viewtopic.php?f=4&t=14869
rfman
Re: 05 206cc window
Post by rfman »
Carried out the adjustment today. It works well, and I adjusted the door striker at the same time.
A previous attempt to correct the window had been to adjust the door striker so that the door was pulled downwards when shutting. This only made things worse and caused an annoying clunk when closing the door.
