I noticed being dumped into limp mode when underload on rainy days! Had just had gearbox overhauled and working well throughout summer, so was not too pleased to experience more gearbox problems. Then antipollution warning every startup, and tickover producing marked vibration at lower than usual revs, till eventually no power at takeoff (and in limp mode).
Suggested to friendly mechanic that he change plugs, renew airfilter and examine HT system. He reported back "All fixed" and produced a water soaked airfilter. "How did that get there?", I asked. "Do'nt know", he said, "but I got 2 pints out from the bottom of the filter box!". He'd examined all the pipe work and wheel arch fittings, which were fine. "So, in case I want to drive in the rain, could you drill some holes to let it all out?" - "No problem, I've already done that", he replied.
Well, it growls a little bit now, but the power is so much smoother, and no more limp-mode.
Now - how does the water get in? It might also help to know how the air gets into the wheel arch/inlet trumpet?
Curious,
Stuart
