hi again!
- fatboyslim
Re: hi again!
The back seat is fixed
Enright
Re: hi again!
Why would you want to?
BCingU,
Neil.
Neil.
- RONALDIQ
Re: hi again!
Just that I saw in the boot (under carpet) there were some audio leads from the boTtom of the rear seat .
Re: hi again!
Under the front edge of the rear seat squab are 2 bolts. Remove them with a 10mm socket and you can pull the seat squab forward and out. If you then need to remove the seat backs, you will find a bolt at the bottom of the seat back- remove and lift the back up and out.
- RONALDIQ
Re: hi again!
Thank you . I also need to see where the spark pugs are in peugeot 206CC 1.6cc . Could that be under the plastic rocker cover?
Re: hi again!
Yep. About 6 torx screws to remove. Fit Bosch super 4's
- RONALDIQ
Re: hi again!
Okey, thank's capncol.
