I'm new here.
- RONALDIQ
I'm new here.
Anyone knows where the spark plugs on 26CC 1.6 engine, are?
- fatboyslim
Re: I'm new here.
Under the black plastic cover on top of the engine
Re: I'm new here.
Then remove the coil pack unit ... think its three small headed bolts but very long ones then pull it straight up. Then the plugs are down the holes ... you'll need a reasonably long extension and plug socket with a rubber insert to hold the plug while you line it up. Bosch Super 4 plugs are good in the Pug engines ..
Take care with the small connection on the right hand end and the black plastic tube next to it which gets very brittle and breaks easily ..
