(pig of a job) But it's a nice feeling when all goes well, Ran the engine for about 15 minutes then turned her off to clear up my tools ready to give it a run out, It was about half an hour before I returned to drive the car, Got in as normal to start the engine, It would not start? an d it's never started since, and that was 6 weeks ago.
So the first thing I did was to check everything That I touched when doing the job, All looked good, So in comes the first expert with his Diagnostic equipment, The only fault showing was heater plug relay not showing, plus a second test showed that the injectors had no power going to them hence it not starting, he found this out by fitting a test lamp to the end of the cables going to one of the injectors, He left without solving the problem, In comes the second expert with his box, He could not find the fault and left, But on this last occasion after he had left I noticed when I tried to start the car the Eco-mode was showing on the dash, so now I decide to check what else is not working, No headlights, No wipers and washers, No radio, in fact the only things working were sidelights, electric windows, and central locking.
So now with more faults in comes the third expert, George came with his little box and can't find any faults other than what's showing, George said more time is needed get it towed to his garage and he will look deeper into it,
George decided that the BSI or ECU would need repairing, cut a long story short, I acquired a second hand BSI, ECU and ignition key and barrel, all the part numbers were the same, by this time with help from the internet the 3 minute rule had been found, and the new second hand parts were fitted, The battery was reconnected using the correct procedure, and hooray the eco-mode as gone replaced with a flashing date and temperature, Lights, wipers, are all working, So now is the important part will it start? No, it will not start, Now we're thinking we've solved the BSI fault but not the original fault of not starting (engine turns over fine and battery charged at times) So George decides to test the preheat fuse and forgets about the 3 minute rule, now we have eco-mode back, (soft re-boot) as been tried many times when eco-mode was showing on both systems,
So I'm now back to the start again with BSI in eco-mode and will not reset, and no power to the injectors stopping the engine from starting, I'm very close to scrapping the car and putting myself in the crusher with it. Who ever solves the problem will also save a life Ha! Ha!
