Hi all can any one help I seen the video on uoutube on open and close manually
So faults roof would not go down just beeps when pressing button
Beeps when driven constant beep until u pull up
So was a warm day thought I will put the roof down manually
Then put it back up agent ok did it step by step to the video
Then struck a problem that the video did not cover
The manual lock in place super but now will not latch back as it should so have gas to leave the manual locks in place as it won't do it it's self any one got any idears
I an taking it for diagnostics on Wednesday
206 cc roof and boot help please
Simtrike
Re: 206 cc roof and boot help please
Help I have immobiliser fault now
I assume it is the indicator wiper switch unit is faulty
As it has all stopped working and the key buttons stopped at the same time
Would any one know if this would cause immobiliser fault
Immobiliser & indicator switch are 2 seperate things. Why do you think it's the indicator switch?
Please give as much detail as to what is happening / not happening.
Enright
What did the diagnostic show up, or were you not able to get it done because of the immobiliser issue?
Also where are you? If you put your location in your profile you might find someone near enough to be able to help you, rather than having to tow it to a garage.
BCingU,
Neil.
Neil.
Simtrike
Hi they are all built into one unit indicator lights wiper and stereo controller
You have to take steering wheel off to get to it
