Front Wing
cabrioman
Front Wing
Post by cabrioman »
I am in the process of trying to rectify the poor repair to the front end.
this is what i'm faced with
Most of it is still straightened out but the one part i can't seem to sort is the O/S wing.
It looks like the curve for the headlight is wrong and when you fit the grille, it doesn't sit right because of the headlight getting in the way.
You can see how bad the light sits on the wing below.
In my opinion, they've fitted the wrong wing but does anyone have any other suggestions?
2002 2.0l SE in Green
Sun Out - Roof Down (whatever the Temperature)
Re: Front Wing
Wing look ok, but that headlight will never sit right with that damaged headlight panel / front panel
