Key fob wouldnt open car.Had to open door manually using key.
Alarm sounded.Now car wont turn over.
Lights on dash were all lighting up.
Noise when key in ignition and button is pressed.
Ive put in new battery in key
When key in ignition is turned to position 1 there is a constant clicking sound from engine area and all the warning lights are on.
Any help please
help
Re: ?IMMOBILISER PROBLEM
What is the voltage across the car battery? This could have just been a flat battery.
PEUG1
Thanks Capncol -soz dont have voltmeter-think I may have charger somewhere
PEUG1
Thanks Capncol -it was the battery-charged it for 1 hour-halfords did free check and say the crank is 450 but should be 550.they suggested a new battery
Re: help
Check out the gear linkages on top of the gearbox and also at the bottom end of the gear stick. You may need to remove the battery and battery box for better access. Make sure the bushes are all intact and the pins that hold the links together are not coming out (we lost 1st, 3rd and 5th when a small pin came out & that side of the linkages came loose).
