Resolved my problem with 206 1.9d multiplexed not starting as problem was with wire 1229 from bm34 to ecu corroded in middle of loom. however my horn now does not work. got horn out and checked horn works ok, checked for voltage on connector when horn on steering wheel pressed ok 12v (can also hear relay in bm34) checked for continuity on pin1 wire 250 16v ve pin 15 ok. checked for continuity on earth wire pin2 mc11k to mc11 earth point ok. any help greatly appreciated. Cheers Andy
horn not working 206 1.9d multiplexed (2002)
fozzybear
fozzybear
Re: horn not working 206 1.9d multiplexed (2002)
Update ran pp2000 got error on airbag ecu -(remote intermittent fault vehicle speed information) and instrument panel - (remote intermittent fault vehicle speed information incorrect value received). could this be related to why horn not working?
Cheers
Andy
Cheers
Andy
