hi All,
wondering if anyone has had any problems with the Clarion CD/Radio. I bought a 1.6 manual 3 months ago and the radio never stores the stations in the correct way. If I play a CD and then go back the the radio all the stations have been mixed up. I have checked that I don't have any auotmatic retuning or anything like that on. Anyone seen the same thing?
many thanks.
Greg
Clarion CD/Radio problem
CB
From one Greg to anther....
I too have exactly the same problem - but figured it was cus i was in Germany where there are millions of radio stations all seemingly operating on the same frequencies, I only have to drive round the corner to lose 3 of the 6 stations i've programmed in. Hadn't really highlighted it as a problem here because BFBS is the only English language station and i can usually find it easily enough....
[img]http://bluntman.d2.net.au/newsmilies/brick.gif[/img]
greglondon
hi,
Thanks for the reply. It's a bit more annoying for me becuase I store 6 stations. When I play a CD thengo back they've all been changed (usually to BBC 2 for some strange reason!). The other strange thing is that the dsiplay sometime shows the correct station, but if you select it, it is actually playing a completely differnt station.
Greg
Greg
Derek
this is a fault but i don't know how it fixed.
this happened all the time with my 1st CC and the stations that changed also defaulted to BBC R2. it was supposedly fixed but it was still doing it when i got it back.
when it went back to get fixed again along with the leaks i didn't get the CC back as i ended up rejecting it so i don't know if it was ever fixed.
it has never happened on the replacement.
Derek
greglondon
Derek
good luck greg.
i know how annoying it is as i always preset the same stations in the same positions even in any courtesy cars i use and to switch stations and get something as annoying as R2 wasn't pleasant
Derek
crazylady
greglondon
Eye See
We lost all our presets when our car went into the dealer once.
They removed and refitted the gearbox so presumably had to disconnect the battery causing the loss. However, I have never had to do this in other cars - All you do is re-enter the code.
Why Radio 2? Perhaps this just happens to be on the default frequency. Every TV we have bought has all channels showing Channel 4 when we got them. This is because the lowest frequency for TV in the UK is 21 and in our area this just happens to be Channel 4!
I'll go now before I bore you all!
Eye See
Eye See
Loyal [b][i][u]ex[/b][/i][/u] CC owner!
