boot lid problem
johnrw
boot lid problem
when i try to open my roof on my 51 plate 206cc the boot lid goes up then starts to judder and the roof won't go up. if i move the roof back and forward by hand it starts to work. it does the same thing when i close the roof.
mattau
Re: boot lid problem
I would guess at a microswitch. Check them out first.
If boot/roof can move under power then it is likely one of the switches shutting things down.
- cabrioman
When was the last time you greased the frame hinges?
It's something not many people thinks about and i have found that alot of my customers have suffered from a slow or failing roof because of this.
2002 2.0l SE in Green
Sun Out - Roof Down (whatever the Temperature)
