My peugeot 206 some knocking sound coming from right side front
Which I have already change complete swing arm , sterbilizer bar, engine mount month a go.
Knocking sound
Re: Knocking sound
Maybe the strut. Try bouncing the car up & down on that corner and look for oil leaking from strut or a broken spring. I take it you changed the anti roll bar vertical link too?
ijawaz
Re: Knocking sound
I have check nothing wrong with front shock
I mean I removed whole thing and check
Do u think sterbilzer bar joint break? Bez I have change both sides but maybe manufacture fault?
Re: Knocking sound
Is it knocking over bumps or when cornering?
ijawaz
Re: Knocking sound
Bumps only cornering no sounds
ijawaz
Re: Knocking sound
Today I have removed both anti roll bars
And I have drive my car no sounds at all
I think anti roll bar studs is lose for those holes
Re: Knocking sound
Did you change the rubber anti roll bar mounts? Maybe those.
Sounds like you are getting to the bottom of it now.
ijawaz
Re: Knocking sound
I have new problem my car display shows when I start the car " anti pollution " message?
Re: Knocking sound
If you are doing lots of short runs that could cause it. If so give the car a decent run to burn off any unburnt fuel deposits in the exhaust system.
When did you last change the air filter? A dirty air filter can cause it to run too rich.
Are you using supermarket fuel, or quality stuff such as BP Ultimate or Shell V-Power?
Is it misfiring at all?
ijawaz
Re: Knocking sound
I use to drive my car short run will give good ride
I will check filters too
I use castrol motor oil
ijawaz
Re: Knocking sound
New issue today when I drive my car on rain today suddenly stops and display says immobilizer fault
