An odd one this... My car has recently started sounding "wheezy" for the first couple of miles after starting it. It's hard to descibe the noise, but it's a sort of delayed rattle, a bit like someone with a wheezy chest breathing, and isn't that noisy but is noticeable.
The car's a 2.0 SE, only 4 months old with just over 4000 miles on the clock. Any ideas?
Wheezy engine
Eye See
Gareth,
Does this happen continually or is it whilst turning?
Power steering makes a wheezing or groaning sound that is quite normal as it pumps fluid around. However, this is normally only heard at low speeds and particularly at or near full lock.
Our car is a 9 month/4500 mile old 1.6, which presumably has the same power steering as your 2.0, and makes the normal sounds. However, more recently I have regularly noticed the power steering is audible above the engine noise whilst pulling away at the 1st few junctions in the morning.
It may be worth checking your power steering fluid reservoir to see that it is full. The power steering on a Belmont I had became excessively noisy and the reservoir was empty, but no sign of leaks externally. It was leaking internally and the bellows were full to bursting point!
Eye See
Eye See
Loyal [b][i][u]ex[/b][/i][/u] CC owner!
Gareth
