Gearbox fault no 5th gear
tony p
Post by tony p »
Im new to this forum, just bought a 54 plate 206cc, been in a very light front end crash,
last job to do is now sort out the gearbox. when the car is in neutral and i push the gear leaver over to the left, it does not spring back to the center, when i push it to the right it springs back as it should, to the center, it will not select 5th gear at all, apart from that, it works perfect, no noises at all, would appreciate any help, thanks
