Roof alarm beep
hawhinella
Roof alarm beep
When I open or close the 206 roof, the roof opens and closes properly but the beep to show you the operation is over does not go on. Then if you release the switch your are using to open or close the roof a continuous beeping alarm goes on. The only way to switch off this alarm is by switching off the engine with th roof either open or closed. Please help me someone!
