steering wheel
206chris
steering wheel
Post by 206chris »
Hi new to the 206 scene i have to replace the comms unit on my 206 does any one know how to get the centre of the sterring wheel off and it also has the air bag aswell. thanks chris
Re: steering wheel
Air bag is held on with two screws at back (pre-mux cars and probably torx header) or clipped on on newer models (multiplex).
Have you got round or rectangular holes on the back of the wheel?
You'll need to disconnect the battery and leave the car for 10-15 mins to allow the air bag system to discharge.
Then once the airbag is off, it's a torx headed bolt holding the wheel to the steering column.
206chris
Re: steering wheel
Post by 206chris »
Hi its got rectanglar holes its a 2003 model .
Re: steering wheel
Ok, them multiplex .. I changed the air bag squib on our a couple of years back.
A small screwdriver through the hole in the back should unclip the air bag. Turn the steering wheel to get move access room. Once it's loose there are two colour-coded wires holding it to the comm unit. And 1 or 2 more for the horn connection.
Make sure the steering wheel is straight ahead when you take it off so it goes back straight ..
Loosen, but don't remove the big bolt, with the correct torx socket and pull the steering wheel loose. You may need wiggle it and to even give it a bash with the flat of you hand to get it to release off the splines. The bolt will stop it flying off and hitting you!
You will probably have to remove the column surround as well.
I think you should then be able get to the comm unit. All goes back in reverse.
Just make sure you disconnect that battery .. if you don't you could trigger the airbag!
When you put the air bag down, have the back of the unit pointing to the floor ... if it does discharge (shouldn't if you leave it for long enough!) it won't try and be the next satellite in orbit around the moon!!!
Hope you got the right comm unit .. the pre and post mux are different and not swappable.
BTW when I change the air bag squib pre-mux one was £35 and mux over £100!!!
206chris
Re: steering wheel
Post by 206chris »
Thankyou very much for your help .so just a small screwdriver through that small hole there is just one hole on back of mine is that right .
206chris
Re: steering wheel
Post by 206chris »
Just to let you know all done and working thanks for your help .
