Glow plugs and Glow plugs relay on Peugeot 206 cc HDI Allure
Gamma Diesels
Post by Gamma Diesels »
HEllo
Does anyone know where the Glow plugs and the glow plugs relay are on a Peugeot 206CC 1.6 HDI Allure?
I have got a fault code 'Pre/post heating relay circuit relay controlled and spark plugs not supplied[edc16c3 EURO3]:Pre heating relay circuit.Spark plugs permanently supplied.'
Someone suggested on another Peugeot forum that it has to be the glow plugs.
I keep getting 'unblock diesel filter ' on the dashboard and apparently it is the glow plugs that fail to help the DPF regenerate.
Re: Glow plugs and Glow plugs relay on Peugeot 206 cc HDI Al
Glow plugs won't cause the failure of DPF regeneration. They are only for starting a cold engine. However to answer your question, the relay is on the back of the battery box While you're at it, check Main fuse 7 (30A) and Fuse 1 (10A) which power the glowplug relay.
