also is anyone selling ?
help needed
mrslegs
help needed
i need to change the passenger seat in my 2002 206cc anyone have any hints and tips on how to.
Re: help needed
It's dead easy. 4 bolts, 1 each end of the runners. Just be sure the replacement seat has the same airbag / pretension plugs underneath as the old one.
mrslegs
Re: help needed
Thank you for the quick reply will it be the same air bag pretension plugs if its the same year ?
mrslegs
Re: help needed
i understand its a common fault with the seats ?
Re: help needed
Not always as some seats have side air bags some don't. It's important you get a seat with the right plugs as if you get the wrong plugs you will get airbag light on which is an MOT fail.mrslegs wrote:Thank you for the quick reply will it be the same air bag pretension plugs if its the same year ?
I see you have put a wanted post up- You might want to state the colour and material you require as well as if it has side airbags or not so that it matches the existing seats.
shadow
Re: help needed
when changing the seats with air bags disconnect the battery for 30mins following the correct proceedure, change the seats re- connect the battery following the correct proceedure.
