sump
brianold
sump
Post by brianold »
Hi!
ihave a striped thread in the aluminim sump on my 206cc 1.6
it is the oil drain hole any suggestions
thanks for any input,
brianold 8)
shadow
Re: sump
Post by shadow »
new sump needed/re-tap bigger thread, either way the sump has to come off so might aswell put a new one on
Re: sump
Try helicoiling it Use heavy grease on the drill and taps to catch the swarf.
shadow
Re: sump
Post by shadow »
i still advise taking the sump off to clean it as there will be fillings sitting at the bottom of the sump from the thread as it will be pushed in by the helicoil (seen it done trust me).
