Peugeot 206 cc 2001 1.6
I have just successfully fitted some reversing sensors and great they are too. However the speaker/bleeper is in the boot and i cant hear it very well. What is the best way through from the boot to the saloon so i can put it perhaps behind a seat???? without interfering with any roof mechanisms.
reversing sensors
- Thar
Re: reversing sensors
There is an inspection hatch through which you can access the boot from the saloon. If you check out the REMOVING/REPLACING THE TAILGATE STRUTS post, it tells you how to access it.
shadow
my reversing display sits nicely on top of the rearveiw mirror, the box of tricks is stuck on the inside of the rear panel in the boot by the rear lights.
davetyler
Yes but where does your wire come through from the rear lights to forward
shadow
as thar said in her post, remove rear seats you will then see the inspection hatch on the drivers side, if you want to put it like mine on the rearveiw mirror you will need to run the wiring with the car's wiring loom that runs under the carpet along the drivers sill then up past the BSI/fuse panel then behind the A pillar cowling,roof cowling which needs removing.
heres a pic (not very good camera phone)
