ROOF MICRO SWITCH LOCATIONS
andyr
Post by andyr »
Hi im wondering if anyone can help me with a issue with my cc's roof!!
the roof opening sequence stops just after the roof descends into my boot and just before the parcel shelf is supposed to pop up.
Can anyone please show me photos of the relevent micro switch(s) that are causing me this pain?
I just want to compare what mine looks like to a known working one as i think the bar that touches the switch is bent out of shape.
Please note when im trying to open the roof and im pressing the button in my car i can hear the mechanism working and i dont get an error tone, the issue simply is the parcel shelf wont raise for the boot lid to shut and the process to complete.
I can still raise the roof from this point, i dont need to manually raise it.
P.S i know its winter soon and i wont need my roof down for a few month unless were hit by a freak heatwave i just want it fixed :)
andyr
Post by andyr »
Re: ROOF MICRO SWITCH LOCATIONS
Welcome to the forum. No need to duplicate your posts. If someone knows the answer they are likely to respond.
andyr
Post by andyr »
yeah sorry about that computer issues too by the looks of it haha,
and thanks.
## also to add is there a compatible switch available from Maplins or is it best to visit peugeot or the scrap yard if this is the part thats needed ?
duet
Post by duet »
Dear andyr,
I think you have the same problem of mine, the answer should be microswitch "I". Try to tie a "wire-tie" to the pin. You will get your problem solved !!!
http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=14017
Let us know here , if my suggestion works.
andyr
Post by andyr »
Hi this definitely looks to be the issue, the thin metal strip was bent out of shape, and when ive tried to bend it back in its fell off, its not snapped just out of its socket if that makes sense?
im going to take the microswitch off this weekend if i can get a day off and decent(ish) weather and try and fit it back together,
Can i ask what did you use to modify the switch and what procedure did you follow?
