Radio
Hayley19
Radio
Post by Hayley19 »
I have had no signal on my radio now for about 3 weeks. I have replaced the aerial and the mounting base but it still doesn't get any signal. I have taken the cd player out and the cable is plugged in at the back. Any ideas? I guess I need to change the aerial cable? Anyone done this before and is it easy?
deeman
Re: Radio
Post by deeman »
try another radio in it if you could just get a loaner off someone for 20mins sounds more like the recever in radio.the cable dosent realy go much on the 206 cc /206 not unless you have snapet it putting new mount on not sure but if you jump into halfords there pretty clude up on it and its free advice take it where you can a say good luck pal
davetyler
Re: Radio
Post by davetyler »
it was the radio on my 206, i bought one from halfords with the connection for the stick on the column. never had a problem since.
