Pedals
- Thar
Re: Pedals
Hi Patsy and welcome to the forum
I have the same problem, in fact I have this problem when driving cars with rubber pedal covers too and it can be dangerous. I now keep an old hand towel in the door space to wipe the bottom of my shoes before I set off.
I'm not sure, there may well be rubber pedal covers, one of the others may be able to advise.
- craigdmjv
Re: Pedals
well i have retro fitted the metal pedals in mine
you can remove them 10mm spanner and allen key and replace with normal 206 rubbers however the accelerator pedal is different you pull top upwards so it unclips then you push the bottom of the pedal towards the right as its on a hinge this can be replaced by a standard 206 pedal from a scrap yard and the rubbers should simply fit on top of the two other pedal bases your best bet is going to a scrap yard and getting the replacement pedals
another option is to put skate board grip material over the metal parts someone of here done it a while back and it apparently worked might be worth a try
Enright
Re: Pedals
If I'm going to spend any longer than 20 mins in the car I slip my right shoe off.
I know that might sound a bit mad, but it has its advantages:
I can feel the pedal better so am more in touch with what the car is doing. This helps with both control and economy.
It also makes damn sure I keep the carpets nice and clean!
BCingU,
Neil.
Neil.
