1.6 automatic gearbox's...are they diferent?
hemz
Post by hemz »
I'm after an automatic gearbox for a 1.6 16v 206cc. But i'm having trouble sourcing one.
Are there different gearbox's for a 1.6 16v 206cc?
According to a breaker he has a gearbox, but said its a : t1f222b30e
and mine (according to my vin) is :t1f222b30b
Would it be compatible?
And the only code i could find on my gearbox was TA96 FAC 1-8.1. Is this not the gearbox code?
hemz
Re: 1.6 automatic gearbox's...are they diferent?
Post by hemz »
Also is there any other model where i can use a gearbox from?
Citroen Xsara/ Xantia
hemz
Post by hemz »
Finally found a gearbox finally and had it delivered. It looks the same but just want to make sure it is according to the gearbox.
The code on mine is : TA96 FAC 1-8.1
and the one i bought: TA96 FAC 1-2.2
Will the last 2 digits make a difference?? and what do they relate to, gear ratio?
Any help appreciated as i plan to install tomorrow and i don't want to go through the whole process just to find out it doesn't fit!!!
