Hi All,
This is my first post!
The problem I'm having with the roof is,
When I try and open it I get the dreaded bleep, I then open the boot, move the shelf off and on the switches, try the roof and it goes no problem! But then when I close the roof the same thing happens, nothing until I open the boot and move the shelf off and on the switches again, then it ok!
I have done a search and can't find anything similar.
But I'm hoping someone else has had and sorted this problem?
Many Thanks, Dave
An Odd roof problem?
- suegriff
Re: An Odd roof problem?
Hi Dave
I had this problem with mine, the switches in the boot area seemed to work one min not the next! theres plenty of posts on here about the switches, but in the end i had to take to the pug dealer
which end up finding bad switches in the boot area
so it cost me a mere £172.50 for switches and to be fixed but it now works
and as i told the guy i handed my money to. the first time it bleeps and dont go i be back
Sue
Sounds like you need to change the micro switch where the blind hooks in (l/h side)
cockneyrebel
Yep definately sound like the micro switch for the pull cover. Glad Sue got hers sorted but when you consider you could probably buy a replacement micro switch from Maplin or RS components for a couple of quid it does make you wonder how peugeot can justify charging £172.50 for a 15 minute job?
- suegriff
Had the whole sensors in boot area replaced just not one!!, but it was worth it as seeing i only paid £ 800 for the car in the first place!! due to the roof not working!!!... theres (well was last week) 206cc in windleys nr boston been rolled but it had all sensors still on it.... i wanted the drivers door but had more dents than the one i got on but thats the way it goes.....
- fatboyslim
That the blue Allure??suegriff wrote:Had the whole sensors in boot area replaced just not one!!, but it was worth it as seeing i only paid £ 800 for the car in the first place!! due to the roof not working!!!... theres (well was last week) 206cc in windleys nr boston been rolled but it had all sensors still on it.... i wanted the drivers door but had more dents than the one i got on but thats the way it goes.....
- suegriff
Yes its a blue one!!
- fatboyslim
Yep and it's in a sorry state,looks like every panel's been damaged and both mirrors fubar'd!!suegriff wrote:Yes its a blue one!!
- suegriff
yep it is, all the bits i wanted are naffed or gone, more or less its mainly paint work mine needs to doors, one got dents in it someone did try to fill it and paint it( its s**t)
the other had a key down it,wheels and bit on sp arch kit need a bit of love too.... we was going to take roof boot sensors but it was raining that day.....
