Won't start - please help.
caseley
Post by caseley »
Hi all,
First off, hello, i'm new here.
I'm after some help. I've just changed the clutch on my 2002 206cc after the release bearing blew up.
After putting it all back together the car will now not start. The car turns over fine and the fuel pump is running i believe however there is no spark. When I changed the clutch i noticed the sensor pointing onto the flywheel was damaged but not excessively.
Any ideas would be greatly appreciated. Will the flywheel sensor cause the car to not start?
Thanks,
Mark
caseley
Re: Won't start - please help.
Post by caseley »
All sorted now - got a new flywheel / crankshaft sensor from a motor factors for £17 and it starts first time now. :)
Without a signal from that sensor there would be no spark. Well diagnosed Mark. Hope the clutch is fine too now.
Welcome to the forum.
