Now that I have been driving my 206cc, Roland Garros edition, I've notice two problems.
1. The automatic windscreen wiper switch mechanism is broken and if the windscreen wipers are activated I can't turn them off unless I shut down engine. Checked with a Peugeot dealer in Izmir, and they said this part isn't in Turkey, does anyone know where I can find this part?
2. The passenger seat airbag give an intermittent fault warning, sometimes when someone is sitting, sometimes when the seat is empty, what causes this? Any help would appreciated.
Electrical Problems
- Kusadasi Dan
Re: Electrical Problems
Your Peugeot dealer should be able to order the part in when they next place a stock order, or on a special delivery.
You could try a few UK dealers and see if they will post the part to you.
You will need the part number.
Passenger airbag could be one of several things. Ideally need to plug into a diagnostic machine to get the codes.
