My problem is with a 1999 1.1 206
There was no work recently conducted on the vehicle and had been running fine, then all of a sudden it was a non starter. Car turns over but will not start. There is no voltage to the fuel pump, and fuses are all okay. Inertia switch is not tripped. All grounds are good.
When connected to diagnosis there are 2 ecu engine management related faults they are:
Intermittent communication failure
Permanent communication failure
I am hoping this is not going to be an ECU rebuild job, but if it is is there anyone here that would have knowledge of common failures with the Magneti Marelli IAW 1AP.80 engine management system?
Or if this is a common wiring fault were is the best place to look, I have already checked the connection under the air box and into the back of the fusebox and of course the dual function relay under the ECU, plugs and sockets.
Any help would be GREATLY appreciated guys, thanks in advance
