Remote key not working
rtbuk999
Post by rtbuk999 »
Key remote problems. My remote key only works for a few hours after replacing the battery, I have tried the resetting via turn off, press A key, turn on etc but still nothing..........HELP its driving me nuts.
encran
Re: Remote key not working
Post by encran »
Hi rtbuk999,
Regards your remote central locking issue. I had this on a 1999 1.1 206
Eventually after replacing the receiver inside the BSI and having the same issues I came to the conclusion that is was the transmitter. Often with these devices if you repeatedly press the unlock button out of range of the receiver the devices become desynchronized. There was a fault with my fob that cause code wandering even thought the button was not pressed. I forked for a new fob, resynchronise it and the problem has not re surfaced in 2 years.
I hope this helps you. Let us know how you got on :)
