roll bars
LornaP
roll bars
Post by LornaP »
hi all i was just wondered if the roll bars on the cc are cosmetic or structual as was thinking of swapping them for the chrome ones.
Thar
Re: roll bars
Post by Thar »
Hi LornaP and wlcome to the forum! :wave:
The roll bars are cosmetic. I swapped mine for chrome which I sourced on Ebay, very easy to do, there's a link to tutorial somewhere on the forum.
Image...............
LornaP
Re: roll bars
Post by LornaP »
Thanx!! :thumbs:
craigdmjv
Re: roll bars
Post by craigdmjv »
Here is my guide to replace roll bar hoops....
1. put the roof down.
2. undo the two bolts at the bottom of the rear bench, one in each foot well you can them pull the seat free.
3. undo the bolts at the bottom of the rear parts of seats, the seats then push up to release from there mountings.
4. undo the bolts for the roll bars which should now be visible, once undone the hoop should just pull upwards, you may also need to reuse the bolts.
5. do this process in reverse to re-assemble make sure the bolts are tight and that the seats are correctly mounted.
6. put the roof back up slowly, and i repeat slowly to make sure the glass clears the hoops as there are some stories of hoops going through windows.
god luck and i hope this helps xx
52nd of February
Re: roll bars
Post by 52nd of February »
Yep definitely cosmetic, the box mine came in said 'WARNING: NOT INTENDED AS A SAFETY DEVICE' :P
You don't actually need to undo any seat bolts though - just pull the back of the back seat forward. Then as craigdjmv said - simply unscrew the bolts off the old ones, pull them out, put your new ones in, screw the bolts back on and voila! It's one of the easiest DIY aesthetic mods you can do to the car haha
craigdmjv
Re: roll bars
Post by craigdmjv »
im not as brave as you 52nd i preferred the long winded route tbh lol :thumbs:
craigdmjv
Re: roll bars
Post by craigdmjv »
I wonder if admin/mods can make my guide a proper guide in a sort of guide section which everyone can see... thanks guys :love-thx:
52nd of February
Re: roll bars
I'm sure Thar could if you asked her nicely? :P
Thar
Re: roll bars
Post by Thar »
Was looking for some links etc. last night to previous posts but had to give up and go to bed...Thar is poorly sick :yuck: Will try and sort something tonight/weekend.
craigdmjv
Re: roll bars
Post by craigdmjv »
please thar
52nd of February
Re: roll bars
Told you she might if you ask her nicely :P
Thar wrote:Thar is poorly sick :yuck:
Get well soon!
