I have a K reg 206cc and recently the electric windows have played up after I've had the roof down - I have to put the roof up and down several times and clip in place before I can get the windows to go back up again, if I pull window switches they just beep. Any ideas why this might be happening?
Electric windows won't go up!
- Thar
Re: Electric windows won't go up!
K reg...as in 1992? You sure about that?huggienuts wrote:Hi
- craigdmjv
you sure it not a 205 cj or cti if it is i'm jealous or if not what year was the car registered should say on the logbook
Sounds as if a microswitch needs adjusting where the roof clamps at the top of the windscreen. Are you getting a "bong" warning chime, if so when?
